Add workflow condition - At least 1 issue must be linked
Celik Vedat July 16, 2018
Dear community,
I've tried to find a solution, but could only find something like "Linked status validation" or a solution with some plugins I don't use. We only use script runner. Someone has a idea for a groovy script to get a resolution here?
Befor a certain transition can be done, there must be at least one issue (relationship does not matter) linked to the issue. I'd like to get this into a code but always struggle with the script runner APIs and I am not really used to groovy..
The condition is "simply": Linked issues != null.
Thanks in advance
Vedat
Payne
July 16, 2018
We used the following script to assure that there is at least one link of a particular type and that the linked issue is complete.
Our script:
import com.atlassian.jira.issue.link.IssueLink
def issueLinks = ComponentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId())
def numClosedPceIssues = 0
for(IssueLink i in issueLinks)
//want only PCE links
if(i.getIssueLinkType().getName() == "PCE")
def linkedObject = i.getDestinationObject()
//want only PCE issues with resolution of Complete
if(linkedObject.getIssueType().getName() == "PCE" && linkedObject.getResolution()?.getName() == "Complete")
numClosedPceIssues++
return numClosedPceIssues > 0
 Sounds more complex than you need, so you can likely pare it down to:
return issueLinks.size() > 0
You may also wish to check inward and outward links if direction doesn't matter, e.g.
def outwardLinks = ComponentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId())
def inwardLinks = ComponentAccessor.getIssueLinkManager().getInwardLinks(issue.getId())
return outwardLinks.size() + inwardLinks.size() > 0
