Added field in script field is breaking script for old tickets - Script Fields
bSte October 5, 2018 edited
I added a new field and updated the code but it breaks the code on all the old tickets, how do I fix this? The above script does not work.
Nic Brough -Adaptavist-
October 5, 2018
Do all five of your variables you are calculating from always have a value?
bSte October 9, 2018
Yes, except in the case where the field does not exist on old tickets, then there are only 4 values.
October 9, 2018
You'll need to cope with the absence of the data in the script, so the script knows to not try to do anything with it.
Imagine you're trying to add 3 fields in the new script.  Instead of
total += fieldValue3
use
if (fieldValue3) { total += fieldValue3 }
I'm not sure I'm following how to go about that. I have tried to different ways of going about it:
def total = ((bvInt + tcInt + rrInt + svInt) / sizeInt) * 100;
def totalNull = ((bvInt + tcInt + rrInt) / sizeInt) * 100;
def result;
if(svInt==1 || 5 || 8 || 13){
return total
}else {
return totalNull
OR
def result
if(svInt!=null){
return total
} else {
return totalNull
October 9, 2018
You need to check if a field value is valid before you try to use it in a calculation.
bSte October 10, 2018
import com.atlassian.jira.ComponentAccessor
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField bvField = customFieldManager.getCustomFieldObject("customfield_17937")
CustomField tcField = customFieldManager.getCustomFieldObject("customfield_17944")
CustomField rrField = customFieldManager.getCustomFieldObject("customfield_17941")
CustomField sizeField = customFieldManager.getCustomFieldObject("customfield_17942")
CustomField svField = customFieldManager.getCustomFieldObject("customfield_19311")
String bvValue = issue.getCustomFieldValue(bvField).toString()
String tcValue = issue.getCustomFieldValue(tcField).toString()
String rrValue = issue.getCustomFieldValue(rrField).toString()
String sizeValue = issue.getCustomFieldValue(sizeField).toString()
String svValue = issue.getCustomFieldValue(svField).toString()
double sizeInt = Integer.parseInt(sizeValue)
double rrInt = Integer.parseInt(rrValue)
double tcInt = Integer.parseInt(tcValue)
double bvInt = Integer.parseInt(bvValue)
double svInt = Integer.parseInt(svValue)
def svTotal = ((bvInt + tcInt + rrInt + svInt) / sizeInt) * 100
def result
result = svTotal
}else {
result = totalNull
return result
Do I also need to validate within the if/else statement itself?
def result
result = svTotal
}else {
result = totalNull
return result
October 10, 2018
No.  The if statement is the validation.  The code I gave before
in English is:
If you have anything at all for fieldValue3, then add it to total
(This will still fail if fieldValue3 is not a number, but the main thing here is that the if is checking to see if there's anything there at all)
October 10, 2018
Sorry, our comments crossed over.  In your code, you're still not checking that you have a value before you try to work with it.
The "if" I've given needs to check a value is there before any conversions or sums.
