Adding Custom Field to Issue Summary
Deleted user September 25, 2011
how can i add custom fieds to issue summary?
i've found this: http://confluence.atlassian.com/display/JIRA043/Adding+Custom+Field+to+Issue+Summary
which is outdated and refers to that: http://forums.atlassian.com/message.jspa?messageID=257247681
which cant help me as i want to add custom date fields...
any help is highly appreciated!
Andreas
lfobel September 28, 2011
Here is an example that works in 4.3:
Add Custom Field to the right side of Details panel
#set ($prnew=$customFieldManager.getCustomFieldObject("customfield_10150"))
<li class="item item-right">
<div class="wrap">
#if (($prnew.isInScope($issue.getProject(), [$issue.getIssueType().getString("id")])) && ($prnew.getValue($issue)))
<strong class="name">$i18n.getText("$prnew.name"):</strong>
<span id="customfield1-val" class="value $prnew.getValue($issue)" >
#displayConstantIcon($prnew) $textutils.htmlEncode($prnew.getValue($issue))
</span>
#end
</div>
</li>
4.4 Version:
<div class="wrap">
<span id="customfield1-val" class="value $prnew.getValue($issue).toString()" >
#displayConstantIcon($prnew) $prnew.getValue($issue)
</span>
#end
</div>
</li>
Dan Buffham
August 18, 2014
Any idea why this would not work in 5.4.3????
Deleted user September 29, 2011
thank you for your reply...
it shows something but unfortunately like this:
Spec Freeze: $textutils.htmlEncode($prnew.getValue($issue))
any hints?
thanks,
Andreas
forget about that, your 4.4 version works!
thank you so much!
This worked for me in 4.3, but in 4.4 the htmlEncode() isnt't working. Add code to the issuesummaryblock.vm file.
#set ($prnew=$customFieldManager.getCustomFieldObject("customfield_10155"))
<div class="wrap">
#if (($prnew.isInScope(null, $issue.getProject(), [$issue.getIssueType().getString("id")]))
<span id="customfield2-val" class="value $prnew.getValue($issue)" >
</span>
#end
</div>
</li>
Here is the needed 4.4 change:
Register today
