Adding Java script to JIRA custom fields
Prasad
Hi
How do i add Java script to custom fields, i need to validate the custom field entry using java script.
Please send me example and procedure to do this.
Thanks In advance
Ram
Chaithra N
April 28, 2013
Philippe MARTIN April 28, 2013
what I meant is that java script gets stripped off in the create/edit popup: if I look at the popup page with firebug, the java script is just not there. On the other hand, If I look at the custom field description, I see it ...
Regards.
Jobin Kuruvilla [Adaptavist]
April 29, 2012
Add it in the description of the field under the field configurations.
http://confluence.atlassian.com/display/JIRA/Associating+Field+Behaviour+with+Issue+Types
I tried to associate javascript (https://confluence.atlassian.com/display/JIRA052/Fields+Allowing+Custom+HTML+or+JavaScript) in the Description of the custom fields but it gets stripped off in the create/edit popup (I checked with firebug). My JIRA version is 5.2.9. Any hints?
Thanks in advance.
Learn more
