Adding Post function to Update Description Field
Peter Trubshaw
I've tried to add a Workflow post function to populate the description field. Unfortunately when I get to enter the info to populate the field, I get a single line for data entry. If I needed line breaks in my description, these are not preserved..
If I am creating the same post function on a Custom field, I get a multi line text box that I can use which does preserve line breaks
Is there something I'm missing?
Peter Trubshaw
using wiki markup in the description field for the post-function works for the missing line breaks.
(although the single line entry for the description field is a pain)
MinC
March 29, 2012
Are you looking to populate the description field in certain transitions or to setting a default value? Probably the following documentation might be useful to you: http://confluence.atlassian.com/display/JIRA/Setting+a+Default+Value+in+the+Description+Field
Register Now
