What am I doing wrong? I have Jira cloud. I have several issue types other than story that I'm trying to add the story point estimate field to.
I go to Admin > Issues > Custom Fields >Story Points > Configure > Edit the Default Configuration > Select all the issue types I want > Select my project > nothing changes on my issues. The story point estimate still only shows up for the story issue type. I've tried adding new context to configure for each issue type but the project list won't show up at the bottom.
Yes, the issues all have the say Issue Type Scheme.
Please help. Thanks!
For a custom field (Story points is implemented as a custom field), you need to do three things to use it on an issue:
A quick cheat though - for admins, there's a "where's my field" function in the issue popups. Try editing an existing issue, look to the top right of the edit screen for "configure fields" and use the option there. It can take you right to the place you need to edit.
Register today
