Adding custom field to Issue Summary
Arianna Fabbri
I'm trying to add a custom field value near to the Issue Summary (on the top left of the issue's details page) and I've found the following link explaining how to do that:
https://confluence.atlassian.com/display/JIRA040/Adding+Custom+Field+to+Issue+Summary
Accordingly to that link I was looking for the file issuesummary.vm in the path WEB-INF/classes/templates/jira/issue/summary/ but I can't find it.
On our Jira setup (6.1.8), the path WEB-INF/classes/templates/jira/issue/summary/ contains only these directories:
field
searchers
table
Where can I find issuesummary.vm file?
Thank you in advance for your help
Arianna
Jobin Kuruvilla [Adaptavist]
July 6, 2014
This is on the old version. In newer versions of JIRA, this has to be done inside a bundled plugin. A similar requirement is explained at http://www.j-tricks.com/tutorials/modifying-atlassian-bundled-plugins. Hope it helps.
July 6, 2014
If it is not too critical, I wouldn't recommend doing it because it is harder to maintain the bundled plugin than editing a velocity template. More pain during upgrades!
Arianna Fabbri
Hi Jobin,
thank you very much for your answer! I'll try to avoid to make any changes inside the plugin... I agree that it would be hard to be maintained!
Arianna Fabbri
Hi Jobin,
another question: is the procedure the same if I would like to add a custom field column to the Link panel?
July 8, 2014
For link panel yes. For subtasks, you can add fields using advanced properties.
Register today
