Adding github releases to jira
Akhil Gopinatha Kurup
February 27, 2018
We are using github as source control and we keep all versions (github tags) in github . is it possible to sync github releases to jira
3 votes
Hartmut Leister
June 9, 2021 edited
If you're not afraid to script this yourself, you can do this using
a stub to do this on python 3.7 would then be
(read the above docs before!)
# get git tags
>>> os.chdir( git_folder_local_path)
>>> git_tags = subprocess.check_output("git tag --list").decode().splitlines()
# get existing jira versions (jira_inst is a connected jira-python instance)
>>> jira_versions = [ vers.name for vers in jira_inst.project_versions( proj_name)]
# get missing jira versions
>>> missing_versions = set( git_tags) - set( jira_versions)
# create missing versions (has to be done via API)
>>> headers = {
'Accept': 'application/json',
'Authorization': 'Basic ' + base64_obfuscated_credentials,
'Content-Type': 'application/json'
>>> def AddProjectVersion( project, name):
data = { "name": name, "project": project }
req = requests.post( JIRA_BASE_URL + "rest/api/2/version", headers = headers, json = data)
if not req:
raise RuntimeError( "API call failed [{}]: {}".format( req.status_code, req.content.decode()))
return req.json()
>>> for vname in missing_versions:
AddProjectVersion( proj_name, vname)
3 votes
Steven de Groot
February 28, 2018
Hi Akhil,
You can integrate GitHub with JIRA using the DVCS connector.
https://confluence.atlassian.com/adminjiraserver/linking-a-bitbucket-or-github-repository-with-jira-938846899.html
-Steven
February 28, 2018
i have integrated this connector i can see the github commits, pull requests in jira tickets , but i want to know how we can sync github version releases in jira releases
Steven de Groot
March 2, 2018
Like • JAK likes this
Eric Nelson
January 3, 2020
I don't follow where this plugin helps. It looks like Akhil is looking for the "JIRA Releases" which are in the "Release Hub" of JIRA to be auto-populated by git tags as seen by Bitbucket.
Like • David Rogers likes this
Alairion-GD
I would like to know this as well.  All the plugin seems to do is add a link to my repo on the side bar.  I'd like to at least be able to enter a GitHub branch/tag URL into my release notes or a comment field or something.
Bhavna Bhawnani
April 1, 2020
Following this. I would also like to know how can i see Releases from Github in JIRA. We use the new Github - JIRA intergation maintained by Github.
Like • 4 people like this
Tiago_Rocha
May 22, 2020
Any news on this? I would like to make a release on Github, add the tag to Jira release and tag the tickets on a specific column with that tag.
Like • 2 people like this
David Jorjani
June 3, 2020
Same request! Has anyone found a solution?
Stefanos Hadjipetrou
September 17, 2020
Any updates on this request?
Eli Y_ Park
December 14, 2020
Following
Pascal Salm December 14, 2020
same here...
Ofir Tehila
December 16, 2020
Same need here
Yehuda Cohen
December 29, 2020
Same here too ...
michael.nguyen
February 4, 2021
following.
Matthew Mims February 5, 2021
Same here. Would make our release management so much easier.
Nathan Dierks
March 30, 2021
This would be incredibly helpful for release management.
Justin Liu
f
yehudamakarov
July 11, 2021
this would be helpful because you can manage your tickets in jira, and generate the release info there and then get it into github with a release there with the fix version
Like • David likes this
Leonardo Viada February 17, 2022
Reaching out to know if there's any update...
Anthony Comito March 5, 2022
hi
David Kahara
June 21, 2022
Is there any update on this? Seems like a feature a lot of people are interested in 🙂
Like • Tamir Melamed likes this
Hartmut Leister June 21, 2022
You should only expect such a feature for Jira Cloud. Atlassian has mostly abandoned feature development for Jira Server and Datacenter.
You might get this solution from github, however.
My script below might be implemented in a github workflow
-> https://community.atlassian.com/t5/Jira-questions/Adding-github-releases-to-jira/qaq-p/738261#M487918
Tenzing Doleck
looking for JIRA cloud as well
Alena Karpova
September 11, 2024
following
Register now
