Adding hyperlink to desctiption text of a field (through field configuration)
Rahul Aich [Nagra]
February 27, 2014
Hi
I want to add a hyperlink to the descriptions of priority field on jira.
I understand I can edit the description through the field configuration, however, I am not sure how i can add a hyperlink to it.
The idea is that, on the create issue screen, the user should get the option to click the hyperlink in the description below it to read the definition of priority that we have defined.
How is this possible?
RambanamP
February 27, 2014
Rahul Aich [Nagra]
February 27, 2014
Thanks Rambanam that helps.
carrhuntc July 20, 2016
This confluence page does not exist:
The page you were trying to reach could not be found. This could be because:
  • The page does not exist.
  • The page exists, but you do not have permission to view it.
