Hi all. I know ive done this in the past, but I feel like perhaps this is no longer a function? I have two custom fields, severity and priority, which have the entries Low, Minor Major, Critical and Blocker. The default priorities field in JIRA has icons in it and displays that icon in the list/database view for easy recognition. When I set up these two new custom fields so I could add my own terms in, I cannot see an option to add in an icon, just add new value or move position in the list. Can anyone help with this? The only discussions ive found so far are very very out of date.
Hi Janine,
The option to add icons to options for custom fields is not currently available for Jira.
We had a feature request for Jira Server suggesting this, but it got opened for almost 8 years with zero votes.
If you need to add more priorities, it's possible to add and edit the system priorities.
Please, go to Jira Settings > Issues > Priorities.
For Severity, it won't be able to change because it's a custom field.
Hope it helps!
Angélica
@Angélica Luz Is there any way to get that feature request re-opened to see if can get some traction on it?
Hi Steve,
As the feature was old, it's not recommended to reopen it. Instead, we can create a new one.
Feel free to raise one on jira.atlassian.com (project JRACLOUD) adding more details about why this feature is important for your environment or post here and I'll create the feature.
Angélica
Hi @Janine Daniels and @Steve Maccharoli,
Just to give you an update, I found a feature request suggesting the ability to customize colors and icons for custom fields:
Please, click to vote and watch to receive updates.
Angélica
Thanks for the head's up. I've voted for the issue, and added myself as a Watcher
to add symbols to custom fields, for me the windows symbols did it.
--> Go to your custom field and press "WindowsKey + ." to insert a symbol.
Hope it helps,
Michael
Thank you! That worked for me, I now have RAG status icons
Hi @Melissa Lawrence @Michael Handl
Can you please let me know what type of field have to be created for these icons?
We are trying to show exactly like your "RAG status" field.
I tried with Rich text field with the icon as default option but it didn't work as the default option is not showing up.
Can you please advise?
R
Hi - I just used a standard dropdown field, with text - did you use the windows shortcut noted by Michael above? I just tried it again with a new dropdown with risk categories, and was able to add the icons that way by using the windows shortcut keys then typing the relevant text after the icon.
I've done this in on-prem and in cloud, both team-managed and company-managed, so it seems like it should work for most cases. The only thing we did find was that randomly some people didn't seem to have the libraries necessary to display the icons on their laptops, but it worked for most users.
Hi @Ram I had the same standard dropdown field which Melissa mentioned. For me it's working on Cloud.
For future reference on the Mac: Ctrl-Cmd-Space opens the keyboard symbols
