The issue collector creates an issue with its id as a label. Is it possible to alter its HTML code in a way to add existing labels so that created issues appear in the existing Jira board?
Thank you
Not sure but issues displayed on board have to match a JQL not necessary labels. So if your board currently display issues having a label X you can update it to also get issues when the reporter is the default reporter of the issue collector if it's use only for that purpose.
Regards
It seems that you can push field values.
https://support.atlassian.com/jira-cloud-administration/docs/customize-the-jira-issue-collector/
