Adding users
Carlyn Burczyk May 6, 2018
How do you add new users to jira? Every discussion ive read so far refers to screen shots of the old look and is referring to a "users tab" that I do not see.
Marcin Kempa
May 7, 2018
Hi @Carlyn Burczyk,
Are you after adding users directly in Jira? If so, this documentation may help you https://confluence.atlassian.com/jiracoreserver/adding-new-users-938846197.html.
If you are looking into adding users in Crowd's internal directory, which is mapped to your Jira instance here is documentation you may follow: https://confluence.atlassian.com/crowd/adding-a-user-18579611.html just create user in a directory that is mapped to your Jira instance.
Hope that helps,
Marcin Kempa
Carlyn Burczyk May 7, 2018
Yea I don't have any top nav. My jira doesnt look like that. How do i get it to appear like that? mine looks like this: Is there a way to change it back to the old view so I have access to the top nav?Screen Shot 2018-05-07 at 6.55.49 AM.png
Nic Brough -Adaptavist-
May 8, 2018
Everything that was in the top navigation bar is in the left bar somewhere, and there is no way to way to change back to the good navigation without moving to server.
Your left navigation bar seems to be missing all the admin functions though, so I don't think you have the rights to add users.  I suspect you need to talk to you admins.
Carlyn Burczyk May 8, 2018
Thanks! I will see if that works.
Amrita Nair June 12, 2018
You can add users in the project settings.
Go to -> JIRA administration -> Projects -> project settings -> Users & roles -> Add users & roles
Marcin Kempa
May 7, 2018
Hi @Carlyn Burczyk
Looks like you are usingjira cloud. Here you can find appropriate docs https://confluence.atlassian.com/cloud/invite-edit-and-remove-users-744721624.html
Best regards
Marcin Kempa
