Adding variables with Bonfire...
qa hammer February 5, 2012
I add a variable through Bonfire in a certain template, but when i use it in an issue - It will just display it as
{var_name} rather then the actual value - ? it's a simple set up a URL and I set it up like so :
Selector document.URL
It displays correctly when i click Test, but in an issue it doesn't it displays {var_name}
gdavidson
March 4, 2012
Just to double-check: Are you typing "{var_name}" directly into the Create Issue form, or did you store it in a template and then select that template from the Use Template dropdown?
