I'm trying to menage some addons and found the following behaviour:
in page of "Manage add-ons", in the list of,
whem I Click in the simbol ">" to expand a specific addon information, the page reloads and I have no acess to plugin information.
This happens for all addons.
At this moment, i Can´t admin add ons: disable, enable, set licences... nothing.
Can someone help?
I have a similar problem when I have active connection to the add on marketplace. When I disable the connection I am allowed to manage add ons. Still frustrating as I have to upgrade add ons manually instead of through the UPM.
Thanks for your advice. I have similar problem in 7.2.6, If I disable the Marketpalce connection I can manage add-on.
Same issue here with Jira v6.4.12 and UPM v2.19.1
It might help here to uninstall your UPM version and update it to the latest version that is compatible with your version of Jira. In your case, I'd recommend trying to use the UPM 2.22.18 version, as this appears to be the most current version that still works with Jira 6.4 versions.
If you can't update it in app with Jira, try these steps
Download the 2.22.18 version from https://marketplace.atlassian.com/apps/23915/atlassian-universal-plugin-manager/version-history
Hi Humberto,
Sorry to hear that you are having this problem. So far I have not been able to recreate this issue. Could you let me know the following?
I am interested to learn more about this problem so that we can help out. It sounds very strange, as if the in page ajax calls that should populate the plugin data are inadvertently causing the page to reload somehow. Maybe a browser plugin might be causing unexpected behavior or a plugin to Jira. It's difficult to tell with what we know so far.
JIRA Info Version 6.2.7
Firefox, Chrome and Edge (all with same error)
Cant' see, as now I have a new error. a Isntaling message since 24th. no acess to this page anymore. see att. file.
Let me try with incognito........
Firefox same error.
Chrome same error.
It might help here to uninstall your UPM version and update it to the latest version that is compatible with your version of Jira. In your case, I'd recommend trying to use the UPM 2.20.7 version, as this appears to be the most current version that still works with Jira 6.2.x versions.
Download the 2.20.7 version from https://marketplace.atlassian.com/apps/23915/atlassian-universal-plugin-manager/version-history
