×Hi Team,
I am facing issue with my Administration password expires every day after couple of hours.
So each time i have to reset password for administration, from my team i am the only the member facing the issue.
I tried to disable and enable admin rights , but no luck.
So please help me with priority
Krishna MM
Hi Krishna. A few questions:
I've not run into this with the JIRA Internal Directory, but I've seen accounts do this when syncing from an external directory and either something has gotten cached wrong or isn't syncing right. Removing and re-adding the user directory connection sometimes helps (note you'll need an internal admin account that's working, and this can be a risky process even with that.) Deleting the account to recreate/re-add it is not advised because that can break a lot of things.
Any errors in the logs? I'm not able to find anything reported by anyone else, so this seems to be a localized problem or an unreported bug.
Have you submitted a support request to Atlassian? That may be the best next step in this case.
>>Yes Under same directory.
>> NO , Verified there is no any add-ons.
Learn more
