Adopt OpenJDK
Allan Libby
Has anyone gotten this to work properly yet with Jira and/or Bitbucket? I've tried Adopt OpenJDK 8 and 11 with no success so far. The documentation says both of these applications (latest version) should support both.
Thomas Deiler
July 15, 2019 edited
Dear @Allan Libby ,
yes I can confirm, running Jira Software 7.13.3 and Confluence 6.15.6 and Jira Core 8.1.x with AdoptOpenJDK (just the JRE) 8 u212.
No problems at all - very stable.
So long
Thomas
Allan Libby
How? I've tried a number of different things from setting the JAVA_HOME and the Java version in Tomcat to no avail at all.
Thomas Deiler
Do use the standalone without bundled JRE? Is Oracle JDK uninstalled? Do you start the application with as SystemD script setting JAVA_HOME as "environment"?
Edit: Is the JRE/JDK read + executable by the user running Atlassian apps?
Allan Libby
Oracle JDK and JRE are uninstalled.  I used the installer from the AdoptJDK website.  I have set the JAVA_HOME variable (the intaller did it as well as adding it to my PATH variable).  I am not sure why setting my JAVA_HOME to "environment" would do anything, that seems like it would break pretty badly as that isn't even a path.
Thomas Deiler
Allan Libby
I think if I was running linux that would be helpful, but I am running Windows, so none of that applies unfortunately ;-(
atlassian, confluence, loom, atlassian intelligence, ai notes, ai-powered meeting notes, atlassian community events, ace, confluence ai, loom ai integration, ai note-taking, atlassian ai features, team '25, atlassian live learning, confluence automation
Unlock AI-powered meeting notes: Join our live learning session! 📹
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!
