Advanced Search using JQL
Eduard Diez
July 10, 2018 edited
Good morning everybody
I'm trying to create a JQL s  JavaScript Chart for JIRA Cloud, and it does not let me do the same as I had in ScriptRunner. Can you help me to do se similar sentence please. I need search the demandes cloned by the Stoties
The JQL is:
issuetype in (Story) AND issueFunction in linkedIssuesOf(issuetype in (Demande), "is cloned by")
Thank's.
3 accepted
Ignacio Pulgar
July 13, 2018
On Cloud, ScriptRunner's issufunction does not work directly in the Issue Navigator, as it requires to use the Enhanced Search section instead. However, filters created and saved through in the Enhanced Search can be used, in example, to feed gadgets. That said, I think it's worth trying to save a filter from the enhanced search and try to use it in JavaScript Chart for JIRA Cloud (either by selecting it, or by specifying a JQL query like: filter=<filter-id>).
Eduard Diez
July 13, 2018
Muchas Gracias intentaré probar lo que me dices.
Un saludo
Like Eduard likes this
Prashant Mali
July 10, 2018
Hi @Eduard Diez ,
You can try below jql which also works here..
issuetype in (Story) AND issueFunction in linkedIssuesOf("issuetype=Task", "is cloned by")
Prashant
Eduard Diez
July 10, 2018
Thank's when I met my code in ScriptRunner is not problem it runs ok, but when I put my code in JavaScript Chart this is all time in error because the function are not recognized.
This is my problem. I need to do the same sentence whitout function linkedIssuesOf or whitout any funtion.
Alexey Matveev
July 10, 2018
What is the error? Did you turn on the Enhanced Search?
http://scriptrunner-docs.connect.adaptavist.com/jiracloud/enhanced-search.html
Eduard Diez
July 10, 2018
Thank's when I met my code in ScriptRunner not problem, but when I put my code in JavaScript Chart this is all time in error because the function are not recognized
Ignacio Pulgar
July 12, 2018
Is it a Jira Cloud instance? Or a Server one?
Eduard Diez
July 12, 2018
In JIra Cloud. Can you help me?
