Am trying to search for reports that have multiple fix versions values. Is that possible to search (using jql) for reports that have more than one fix version set ?
Nelson
This worked for me. A search for issues with multiple fixVersions.
fixVersion <= earliestUnreleasedVersion() AND fixVersion > earliestUnreleasedVersion()
This worked for me, too! Thanks!
While this is definitely helpful, it wouldn't find items with multiple versions in the future (that would be twice > earliestUnreleasedVersion() )
Voted because it's better than nothing!
Like Brecht said already, this is not an exact solution. It is a heuristic which works sometimes, but not in most cases I am interested in. In my environment, we can have both multiple released or multiple unreleased versions, plus of course by chance the lucky case covered by this JQL here.
Work for me too, tks a lot
awesome! love the simplicity!
You can this in a normal 2d Gadget - your x axsis can be fix version - you can find the issues whcihc are mapped to more than one fix version this way - not a direct solution but a good workarround
