Im building a plugin for JIRA 4.4, what is the cause and how to resolve it:
see below screenshot of the error:
If JAVA 1.7 is installed and running this can be the problem here:
Resolution to such case:
Follow Atlassian Documentation here
https://developer.atlassian.com/display/DOCS/Installing+the+Atlassian+Plugin+SDK
, in addition to looking at below notes:
-Uninstall JRE 1.7
-Uninstall JDK 1.7
-Delete existing environment varibles (windows: delete previous wnvironment varibles to JAVA_HOME and JRE_HOME) from user and system varibles)
- Make sure you set Atlassian plugin SDK bin directory path into PATH varible in both user and system varibles (leave if found other values in the value field just separate by ';')
-Start fresh JAVA installation for 1.6
-Install JDK 1.6 or the latest updated 1.6 JDK
-Restart Computer
-Set the new JAVA_HOME and JRE_HOME varibles in user and system varibles (JDK path should point the root installation directory of the JDK 1.6 JRE to bin directory ex: JAVA\jre1.6\bin)
See: https://developer.atlassian.com/display/DOCS/Setting+JAVA_HOME
-Now build your plugin again following Atlassian Documentaion here:
Any one get into this problem, it seems the services did not work inorder and caused this problem, any clue?
