After plugin installation by default some of the modules disabled. Why?
rambabu patina
July 7, 2013
After plugin installation by default some of the modules disabled. And when we point a mouse on it showing 'Module cannot be modified'. And that module type is 'Module-Type'. Under this module remaining all modules has been disabled.
Stack trace is below:
2013-07-08 17:49:17,073 Spring executor 28 ERROR admin 938x937x1 3641r5 fe80:0:0:0:b19d:97d5:4cc:a958 /rest/plugins/1.0/ [osgi.container.felix.FelixOsgiContainerManager] EventDispatcher: Error during dispatch.
java.lang.LinkageError: loader constraint violation: loader (instance of org/apache/felix/framework/ModuleImpl$ModuleClassLoader) previously initiated loading for a different type with name "org/dom4j/Element"
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.findClass(ModuleImpl.java:1829)
at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:716)
at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.getDeclaredMethods(Class.java:1791)
at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:460)
at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:443)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.buildLifecycleMetadata(InitDestroyAnnotationBeanPostProcessor.java:202)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.findLifecycleMetadata(InitDestroyAnnotationBeanPostProcessor.java:190)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessMergedBeanDefinition(InitDestroyAnnotationBeanPostProcessor.java:119)
at org.springframework.context.annotation.CommonAnnotationBeanPostProcessor.postProcessMergedBeanDefinition(CommonAnnotationBeanPostProcessor.java:275)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyMergedBeanDefinitionPostProcessors(AbstractAutowireCapableBeanFactory.java:745)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:448)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:300)
at com.atlassian.plugin.osgi.bridge.external.SpringHostContainer.create(SpringHostContainer.java:24)
at com.atlassian.plugin.osgi.external.SingleModuleDescriptorFactory.getModuleDescriptor(SingleModuleDescriptorFactory.java:44)
at com.atlassian.plugin.osgi.factory.UnrecognizedModuleDescriptorServiceTrackerCustomizer.canFactoryResolveUnrecognizedDescriptor(UnrecognizedModuleDescriptorServiceTrackerCustomizer.java:85)
at com.atlassian.plugin.osgi.factory.UnrecognizedModuleDescriptorServiceTrackerCustomizer.addingService(UnrecognizedModuleDescriptorServiceTrackerCustomizer.java:55)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:896)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:261)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:233)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:840)
at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:864)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:732)
at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:662)
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:3726)
at org.apache.felix.framework.Felix.access$000(Felix.java:80)
at org.apache.felix.framework.Felix$2.serviceChanged(Felix.java:717)
at org.apache.felix.framework.ServiceRegistry.registerService(ServiceRegistry.java:107)
at org.apache.felix.framework.Felix.registerService(Felix.java:2847)
at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:251)
at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.registerService(OsgiServiceFactoryBean.java:310)
at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.registerService(OsgiServiceFactoryBean.java:279)
at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean$Executor.registerService(OsgiServiceFactoryBean.java:95)
at org.springframework.osgi.service.exporter.support.internal.controller.ExporterController.registerService(ExporterController.java:40)
at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.startExporter(DefaultMandatoryDependencyManager.java:320)
at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.checkIfExporterShouldStart(DefaultMandatoryDependencyManager.java:261)
at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.discoverDependentImporterFor(DefaultMandatoryDependencyManager.java:254)
at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.addServiceExporter(DefaultMandatoryDependencyManager.java:187)
at org.springframework.osgi.service.dependency.internal.MandatoryDependencyBeanPostProcessor.postProcessAfterInitialization(MandatoryDependencyBeanPostProcessor.java:46)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsAfterInitialization(AbstractAutowireCapableBeanFactory.java:361)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1344)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:423)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Please any one can help me regarding this.
Patina
Renjith Pillai
July 7, 2013
Which plugin is it? That appears to be packaging jar files which are already provided in the runtime environment.
rambabu patina
July 8, 2013
Hi Renjith,
This is Jira Imporeters plugin and jira version is 5.2.10. Here i am going to customize the JIM 4.1.4 for jira 5.2.10 and jira.version element changed in pom.xml file.
Patina
Register now
