Aggregate Children Based on a Condition
Todd_Levinson March 10, 2020
I'm trying to create a column in a structure that joins the summaries of each issue in an epic based on the sprint each issue is in. For example, I want a comma separated list of all the issues in "Sprint 1". I see how to use an aggregation function to do this for all the issues, but can't figure out if there is a way to aggregate based on a conditional statement.
Egor Tasa [ALM Works]
March 10, 2020
Hi Todd,
You can aggregate things conditionally, so the formula you are looking for is probably:
JOIN#subtree{IF(sprint="Sprint 1", summary)}
Note that it works if only one sprint at a time is assigned. If issue is a part of several sprints you'd have to use IF(SEARCH("Sprint 1", sprint), summary)
Please, let me know if this helps.
Egor Tasa
ALM Works
Todd_Levinson March 11, 2020
Thanks so much. This works. In the documentation it uses semi-colons between arguments in the IF function. Are commas and semi-colons interchangable?
March 11, 2020
Yes, you can use either comma or semicolon.
Egor
