Alternative to Tempo Timesheets
Daniel Tarpey July 23, 2014
We have been using Tempo to help manage time logs, the main reason for using it is the timesheet view where you can easily book time to issues, view total time logged for that day/week/month and the team functionality that allows a manager to see this teams work logs.
Unfortunately Tempo does not work with different time zones so we are looking for an alternative with the above functionality, does anyone know of a plugin that will provide this?
Key requirements:
  • Accessed through JIRA
  • Calendar view that can be edited
  • Permissions to set a manager and their team
Hanna Blomqvist June 5, 2017
Has anyone found any good alternatives to Tempo? After the latest cloud version was introduced we're facing too many problems and lacking too many useful features.
Martin Gregory
Yeah  - me too.
As the OP said, if you find something with the timesheet view for entering please let us all know.
Martin Gregory
FWIW "All In One Time Timesheets" plus "Work Time Calendar" is proving to be great for us
Like • Alexey Grevtsev likes this
Mike Kulakov May 22, 2020
Check out Everhour Jira integration.
Everhour automatically syncs your Jira projects. It also keeps track of changes of project and task titles, in order to reflect the newest title on the timesheet. This is a striking difference with other tools where they force you to manually duplicate projects, match and change them.
Worth giving a try.
Shawn Masters
May 22, 2020
Does it handle Capacity/Velocity and Budgeting?
Mike Kulakov May 23, 2020
1. Yes, you can set up a budget for each project (total or weekly / monthly). You can also prohibit tracking time over this budget and set up an email notification, for example, when the budget approaches 80%. Budgets can be configured so that only administrators will see them, or all members.
2. For each team member, you can specify the weekly capacity and control it on a separate dashboard. And you can also use our Schedule to plan work on different projects based on capacity and visually control the planned time against the actual spent.
George Mihailoff
November 25, 2018
There is a non-trivial answer to this. Why people still using manual work logging? One app or another app, what the difference?
The difference is here --> Quantify TimeSpent Jira App
Data + Agile + Jira = Quantify
Shawn Masters
November 26, 2018
Executive team requires the Project Managers to justify all work done as they have Consultants on their teams. I havent seen this App yet and will check it out to see if it would fit our needs.
Martin Gregory
We're using "Work Time Calendar" for logging time in a nice calendar form, and "All In One Timesheets" for reporting.
Loving them both.  Fantastic service, simple effective products.
Shawn Masters
May 9, 2018
Have you found anything to manage Budgets and Portfolios?
Tempo has a nice idea....but they keep dragging their butts on releasing a working product to Jira Cloud.
Shawn Masters
July 20, 2017
Did anyone find a replacement for Tempo after migration the timesheet addon is absolutely TeRRIBLE
Martin Gregory
Like • Jaroslav Pavlicek likes this
Shawn Masters
July 21, 2017
Thanks Martin, I ll take a look into those. Do they have an addon for managing Budget data or Portfolios?
Vladi
May 3, 2018
I look for the same thing, we have Jira Cloud and we want to track the internal and external cost at any point of time. I know Tempo Budget might do the work only for Jira on a local server. Any thoughts?
gilesthefourth July 28, 2014
Hi Daniel,
Are you sure the Tempo plugin isn't suitable? See Viðar Svansson [Tempo] comment here:
https://answers.atlassian.com/questions/154700/managing-time-tracking-for-users-located-in-different-timezones-logging-work-in-jira
Also, any avaliable plugins with the functionality you're searching for can be found here:
https://marketplace.atlassian.com/search?application=jira&category=Time+tracking&cost=&hosting=&marketingLabel=&q=timesheet
Let me know if you have any further questions.
James
Register now
