Angular 2.x jira plugin integration
Laurentiu Nicolae
Good day.
I am fairly new in Jira development and I was wondering if there is any possibility to integrate Angular 2.x(4/5) as a web resource into a jira plugin(maybe make use of angular custom tags in velocity templates this way).
I am trying to build a table custom field and it would be of great help in this matter, any sugestion is more than welcomed.
Thank you
3 votes
somethingblue
January 25, 2018
Hi Nicolae,
I haven't seen a bunch of resources regarding this but I want to pass along what I found:
The first link is a discussion about developing with Angular and JIRA while the second is an actual add-on that uses Angular 2 that you can use as a reference/learning material.
Branden
Laurentiu Nicolae
Thank you kindly for your reply. This information is an eye opener for me. Thanks a lot! :-)
nija_kanthan August 22, 2018
@somethingblue Thanks a lot :)
Chris Langenberg February 26, 2020
Hey there,
i created a little guide, to demonstrate how Angular can be integrated into Jira. You can give it a read if you want and you are still interested.
https://github.com/scitotec/angular-in-jira
Nir Haimov
Hi @Chris Langenberg
I followed your article, however, the page in the project not showing the angular content, the page stay with empty app-root element (from the index.vm)
Register today
