I'm using a system where someone else has already done some configuration. Among other things, he has a request come in from the portal and then has it create a bunch of tasks using workflow/postfunctions (the Bob Swift add on)
I was wondering if there was any way to report on workflow and related postfunctions so I could see where this workflow was set? it's a pain to have to go into workflow transitions individually to see what's happening.
If you are not using JIRA Cloud and are an admin you can export the Workflow as XML and search in the file for the add-on key (shown in Manage Add-ons). In Cloud you'd have to generate a backup and unpack that locally to find the same information
Help us plant more trees
