Anyone use grinder to performance test Jira 5.2x?
Bryan Karsh
February 11, 2013
When I run the grinder scripts, it keeps truncating my url from http://example.com/jira to http://example.com -- in other words, ignoring the tomcat context I have set up for jira.
Not sure where I modify that setting. documentation here is pretty sparse:
https://confluence.atlassian.com/display/ATLAS/JIRA+Performance+Testing+with+Grinder
tier-0 grump
February 13, 2013
Guilty as charged over the sparse documentation :-)
Youre'right - the script simply assumes it's a standalone and has no context. If you are using the harness script directly you should be able to go harness.sh http://localhost:8090/jira and it should pick up the context path. I think you may have stumbled on a bug though, as we always test against standalone, which doesn't use a context path
Bryan Karsh
February 14, 2013
Hi James -- tried:
./harness.sh http://localhost:8080
-- getting errors like so:
2/14/13 4:30:54 PM (thread 0 run 0 test 100): Aborted run due to Jython exception: extraction pattern not matching: [title":"Introduction".*?renderedGadgetUrl":"http:\\/\\/.*?(\\/.*?)"] [calling TestRunner]
        File "/home/monitor/grinder-jira-performance-testing/src/main/resources/test_scripts/./env.py", line 56, in extract
        File "/home/monitor/grinder-jira-performance-testing/src/main/resources/test_scripts/./dashboard.py", line 156, in notLoggedIn
        File "/home/monitor/grinder-jira-performance-testing/src/main/resources/test_scripts/./interactions.py", line 78, in goHome
        File "./agent_issue_browser.py", line 34, in __call__
Looks like I might need to modify Regex... I had modified my system default dashboard. Any tips?
Tobias Heinemann
Maybe some of you are using SSL. The regular expressions are pretty picky and will just work with HTTP and not with HTTPS. Either change all RegEx or switch to HTTP.
Deleted user May 15, 2013
I ve gzip compression turned off and I still have this error:
Aborted run due to Jython exception: extraction pattern not matching: [id":"10002.*?renderedGadgetUrl":"http:\\/\\/.*?(\\/.*?)"] [calling TestRunner]
Sunil Pothireddy [Intel] November 6, 2013
11/7/13 4:23:51 PM (process vmsdajra004.fm.intel.com-0): Error running worker process (Java exception initialising test script
File "/opt/atlassian-jira-performance-tests/target/classes/test_scripts/./env.py", line 35, in request
File "/opt/atlassian-jira-performance-tests/target/classes/test_scripts/./dashboard.py", line 9, in __init__
File "/opt/atlassian-jira-performance-tests/target/classes/test_scripts/./interactions.py", line 35, in ?
File "./agent_project_manager.py", line 4, in ?)
Can we use FixGrinderData-JIRA5.jar on JIRA 6.1.1 as well as there is no new latest plugin for JIRA 6 ?
Also running into these errors can anyone suggest me how to fix these
Error :
11/7/13 4:23:51 PM (process xxxx004.fm.xxxx.com-0): Error running worker process (Java exception initialising test script
Caused by: net.grinder.script.NotWrappableTypeException: Failed to wrap http://jira-fm-dev.devtools.xxxx.com:8080/</em<>>
at net.grinder.engine.process.instrumenter.MasterInstrumenter.createInstrumentedProxy(MasterInstrumenter.java:99)
at net.grinder.engine.process.TestData.createProxy(TestData.java:93)
at net.grinder.script.Test.wrap(Test.java:100)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:48)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorIm...
Louis Williams
May 7, 2013
I get the below error when I try to run the FixDataGrinder jar file on my Jira instance. Any suggestions here would be appreciated since Atlassian has told me that support is out of scope for this tool even though the instructions clearly told me which files to install and where to do this test.
I am running 5.2.9 of Jira and I am NOT a java developer.
  • The version 5 of the jar was installed
  • The jira perfromance tools will be run from a different server as recomended
  • The Server has a local administration account
  • It was disconnected from crowd SSO
From everything I read, I did follow the instructions so I am not sure what went wrong.
Oops - an error has occurred
System Error
A system error has occurred.
Please try submitting this problem via the Support Request Page
Otherwise, please create a support issue on our support system at http://support.atlassian.com with the following information:
a description of your problem
cut & paste the error and system information found below
attach the application server log file ( /opt/atlassian/logs/jira/atlassian-jira.log )
Cause:
java.lang.NullPointerException
Stack Trace: [hide]
at com.atlassian.jira.issue.managers.DefaultIssueManager.getIssuesSortedByIds(DefaultIssueManager.java:269)
at com.atlassian.jira.issue.managers.DefaultIssueManager.getIssues(DefaultIssueManager.java:163)
at com.atlassian.jira.issue.managers.DefaultIssueManager.getIssueObjects(DefaultIssueManager.java:169)
at sun.reflect.GeneratedMethodAccessor581.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$AbstractMultiTenantAwareInvocationHandler.invokeInternal(MultiTenantComponentFactoryImpl.java:181)
at com.atlassian.multitenant.impl.MultiTenantComponentFactoryImpl$MultiTenantAwareInvocationHandler.invoke(MultiTenantComponentFactoryImpl.java:211)
at com.sun.proxy.$Proxy81.getIssueObjects(Unknown Source)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:129)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy1575.getIssueObjects(Unknown Source)
at com.atlassian.jira.grindergenerator.GrinderGenerator.populateProjectsAndIssues(GrinderGenerator.java:88)
at com.atlassian.jira.grindergenerator.GrinderGenerator.populateLists(GrinderGenerator.java:57)
at com.atlassian.jira.grindergenerator.GrinderGenerator.fixGrinderData(GrinderGenerator.java:38)
at com.atlassian.jira.grindergenerator.web.GrinderDataGeneratorAction.doExecute(GrinderDataGeneratorAction.java:29)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
at webwork.action.ActionSupport.invokeCommand(ActionSupport.java:433)
at webwork.action.ActionSupport.execute(ActionSupport.java:157)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:82)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:221)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:150)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:153)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:78)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
at com.almworks.jira.structure.web.AbstractStructureServletFilter.doHttpFilter(AbstractStructureServletFilter.java:45)
at com.almworks.jira.structure.web.AbstractStructureServletFilter.doFilter(AbstractStructureServletFilter.java:33)
at com.atlassian.labs.remoteapps.modules.permissions.ApiScopingFilter.doFilter(ApiScopingFilter.java:60)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:234)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55)
at com.atlassian.bonfire.web.filters.BonfireP3PFilter.doFilter(BonfireP3PFilter.java:57)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
at com.atlassian.labs.remoteapps.modules.oauth.OAuth2LOFilter.doFilter(OAuth2LOFilter.java:70)
at com.atlassian.labs.remoteapps.util.http.bigpipe.RequestIdSettingFilter.doFilter(RequestIdSettingFilter.java:22)
at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:206)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:179)
at net.bull.javamelody.PluginMonitoringFilter.doFilter(PluginMonitoringFilter.java:86)
at net.bull.javamelody.JiraMonitoringFilter.doFilter(JiraMonitoringFilter.java:85)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:74)
at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
sumitnagal April 12, 2013
Same issue, not sure if there is solution. I have maven as well as harness both, which are failing because of this reason. can anyone help ...
4/13/13 1:13:36 AM (thread 0 run 0 test 100): Aborted run due to Jython exception: extraction pattern not matching: [title":"Introduction".*?renderedGadgetUrl":"http:\\/\\/.*?(\\/.*?)"] [calling TestRunner]
File "/Users/autolab/jira/PerformanceTest/Grinder/jira-performance-tests/src/main/resources/test_scripts/./env.py", line 56, in extract
File "/Users/autolab/jira/PerformanceTest/Grinder/jira-performance-tests/src/main/resources/test_scripts/./dashboard.py", line 156, in notLoggedIn
File "/Users/autolab/jira/PerformanceTest/Grinder/jira-performance-tests/src/main/resources/test_scripts/./interactions.py", line 78, in goHome
File "./agent_project_manager.py", line 34, in __call__
Casey Schmit April 28, 2013
I had the same problem. I turned off gzip comression for JIRA on the General Configuration page and everything started working as expected.
JohnA
February 11, 2013
Hi Bryan,
Are you specifying the full context path in the "-Djira.context.path=/jira" argument when launching the test? The default is just "-Djira.context.path=/" and I believe this would lead to the truncation of the context path that you are experiencing when launching the grinder tests if you don't explicitly specify your full context path on startup.
All the best,
John
Bryan Karsh
February 12, 2013
Thanks John,
I don't have maven installed -- how do you indicate context when using the harness script?
Register now
