AppLink problem
Alexey Astafyev
July 11, 2022 edited
Hi there.
We have link between Jira and Confluence.
On Confluence side everything works fine.
But on Jira side we get an error when try searching - The Jira server was contacted but has returned an error response. We are unsure of the result of this operation.
In debug mode on Jira side:
[o.apache.http.headers] http-outgoing-91801 >> GET /rest/api/search?cql=text+%7E+%22test1%22+AND+type+NOT+IN+%28attachment%2Ccomment%29&limit=10&expand=body HTTP/1.1
[o.apache.http.headers] http-outgoing-91801 >> Authorization: OAuth oauth_token="$token$", oauth_consumer_key="$key$", oauth_signature_method="RSA-SHA1", oauth_timestamp="1658219496", oauth_nonce="$nonce$", oauth_version="1.0", oauth_signature="$signature$"
[o.apache.http.headers] http-outgoing-91801 >> Host: conf.domain.tld
[o.apache.http.headers] http-outgoing-91801 >> Connection: Keep-Alive
[o.apache.http.headers] http-outgoing-91801 >> User-Agent: Apache-HttpClient/4.5.13 (Java/11.0.13)
[o.apache.http.headers] http-outgoing-91801 >> Accept-Encoding: gzip,deflate
[o.apache.http.wire] http-outgoing-91801 >> "GET /rest/api/search?cql=text+%7E+%22test1%22+AND+type+NOT+IN+%28attachment%2Ccomment%29&limit=10&expand=body HTTP/1.1[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 >> "Authorization: OAuth oauth_token="$token$", oauth_consumer_key="$key$", oauth_signature_method="RSA-SHA1", oauth_timestamp="1658219496", oauth_nonce="$nonce$", oauth_version="1.0", oauth_signature="$signature$"[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 >> "Host: conf.domain.tld[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 >> "Connection: Keep-Alive[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 >> "User-Agent: Apache-HttpClient/4.5.13 (Java/11.0.13)[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 >> "Accept-Encoding: gzip,deflate[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 >> "[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "HTTP/1.1 403 [\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Server: nginx/1.16.1[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Date: Tue, 19 Jul 2022 08:31:36 GMT[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Content-Type: application/json[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Transfer-Encoding: chunked[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Connection: keep-alive[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Set-Cookie: JSESSIONID=2E51CBA0972CC623249600E4FA764D4E; Max-Age=86400; Expires=Wed, 20-Jul-2022 08:31:54 GMT; Path=/; Secure; HttpOnly[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Cache-Control: no-store[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Expires: Thu, 01 Jan 1970 00:00:00 GMT[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "X-Content-Type-Options: nosniff[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Content-Encoding: gzip[\r][\n]"
[o.apache.http.wire] http-outgoing-91801 << "Vary: User-Agent[\r][\n]"
[o.apache.http.headers] http-outgoing-91801 << HTTP/1.1 403
[o.apache.http.headers] http-outgoing-91801 << Server: nginx/1.16.1
[o.apache.http.headers] http-outgoing-91801 << Date: Tue, 19 Jul 2022 08:31:36 GMT
[o.apache.http.headers] http-outgoing-91801 << Content-Type: application/json
[o.apache.http.headers] http-outgoing-91801 << Transfer-Encoding: chunked
[o.apache.http.headers] http-outgoing-91801 << Connection: keep-alive
[o.apache.http.headers] http-outgoing-91801 << Set-Cookie: JSESSIONID=2E51CBA0972CC623249600E4FA764D4E; Max-Age=86400; Expires=Wed, 20-Jul-2022 08:31:54 GMT; Path=/; Secure; HttpOnly
[o.apache.http.headers] http-outgoing-91801 << Cache-Control: no-store
[o.apache.http.headers] http-outgoing-91801 << Expires: Thu, 01 Jan 1970 00:00:00 GMT
[o.apache.http.headers] http-outgoing-91801 << X-Content-Type-Options: nosniff
[o.apache.http.headers] http-outgoing-91801 << Content-Encoding: gzip
[o.apache.http.headers] http-outgoing-91801 << Vary: User-Agent
In debug mode on Confluence side
[http-nio-8090-exec-35] [atlassian.seraph.filter.BaseLoginFilter] doFilter doFilter : ____ Attempting login for : '/rest/api/search?cql=text+%7E+%22test1%22+AND+type+NOT+IN+%28attachment%2Ccomment%29&limit=10&expand=body'
[http-nio-8090-exec-35] [atlassian.seraph.filter.PasswordBasedLoginFilter] login login : No user name or password was returned. No authentication attempt will be made. User may still be found via a SecurityFilter later.
[http-nio-8090-exec-35] [atlassian.seraph.filter.BaseLoginFilter] doFilter doFilter : Login completed for 'null' - os_authstatus = 'null'
[http-nio-8090-exec-35] [atlassian.seraph.filter.SecurityFilter] doFilter doFilter : Storing the originally requested URL (atlassian.core.seraph.original.url=/rest/api/search?cql=text+%7E+%22test1%22+AND+type+NOT+IN+%28attachment%2Ccomment%29&limit=10&expand=body)
[http-nio-8090-exec-35] [atlassian.seraph.filter.SecurityFilter] doFilter doFilter : requiredRoles = []
[http-nio-8090-exec-35] [atlassian.seraph.auth.DefaultAuthenticator] getUserFromCookie getUserFromCookie : Got username : 'null' from cookie, attempting to authenticate user is known
[http-nio-8090-exec-35] [atlassian.seraph.auth.DefaultAuthenticator] getUser getUser : User not found in either Session, Cookie or Basic Auth.
[http-nio-8090-exec-35] [atlassian.seraph.filter.SecurityFilter] doFilter doFilter : Setting Auth Context to be 'anonymous '
It turns out that Confluence can't find user with needed token. I suspect that successful authentication should include something like:
[atlassian.seraph.auth.DefaultAuthenticator] getUserFromSession getUserFromSession : Session found; 'user' is present
But it's absent
Any ideas to resolve/debug the issue?
Alexey Astafyev
July 19, 2022 edited
*** DELETED ***
Alexey Astafyev
July 14, 2022 edited
*** DELETED ***
Alexey Astafyev
*** DELETED ***
Alexey Astafyev
*** DELETED ***
