Dear Support-community,
please excuse my opening yet another question for the application linking. I was unable to find my problem configuration in the other questions.
Situation
Summary
Ideas
Could you give me a little help to get me going in the right direction?
Thanks, Immo
Hi there,
The best way to get some additional visibility into what is happening during these types of failures is by leveraging the applinks diagnostics plugin. This will run several tests between the 2 applications and spit out a diagnostic that should give us something to go on. Here's a link to this add-on.
https://marketplace.atlassian.com/plugins/com.atlassian.applinks.applinks-diagnostics-plugin
Essentially you'll want to install it on both JIRA, and Confluence, and then run the test. I believe you will need to download and manually upload the jar file to install it on the Confluence side.
Thanks for the hint, regrettable its not yet compatible to confluence 5.7.
I did install it with our JIRA instance, but as I'm unable to generate the app link from JIRA towards Confluence, I find no diagnosable links there .
But I'm open for similar suggestions!
-Immo
Register now
