×With our Jira<->Stash integration, we use a proxy for adminstering SSO. I'd like to bypass SSO for Application Link work; what pattern(s) would that be?
Is it /rest/applinks/
1.0
/*, or are there other patterns that need to be matched?
It depends on what you're trying to do. If you're just looking at the getting the application links to be configurable and such - then /rest/applinks/* would probably do it. But if you're looking at functionality that uses application links you'll more than likely have to whitelist the entire /rest going server to server.
