×I have created a custom field called "Sprint" to capture the month a task will be completed (e.g. March 2013). I am able to search across all projects for issues that are open, in progress or re-opened and are in the sprint version "March 2013." When I perform this query, I get over 40 results in the search issues screen. After saving this filter (shown below), I tried to apply it to the dashboard gadget (Greenhopper Agile Gadget) but it stating there are no issues part of the filter.
Filter: status in (Open, "In Progress", Reopened) AND "Sprint " = "March 2013" ORDER BY priority DESC
I thinking this has to do with the custom field 'sprint' I created since I am only able to search using the advanced search screen and not the basic. Is the custom field not searchable through the dashboard gadget? If not, how do I enable custom fields to be searchable when I apply filters to dashboard gadgets.
This is a big road block for my team using JIRA.
Thanks for your help!
Hi Phil,
just to ensure, you're not went into a common trap: Do you have re-indexed the db after you created the custom field?
Without a re-index new custom fields do work partially but not overall within JIRA/Greenhopper.
Cheers
Kai
