I am tying to setup a workflow transition to archive issues. To do this I am trying to use a ScriptRunner Post Function script.
import com.atlassian.jira.issue.archiving.ArchivedIssueService
import com.atlassian.jira.issue.archiving.ArchivedIssueService.ValidationResult
import com.atlassian.jira.issue.archiving.ArchivedIssueService.ArchivingResult
import org.apache.log4j.Logger
import org.apache.log4j.Level
def log = Logger.getLogger("com.wmic.archive")
log.setLevel(Level.DEBUG)
ArchivedIssueService archivedIssueService = ComponentAccessor.getComponent(ArchivedIssueService.class)
ValidationResult validationResult = archivedIssueService.validateArchiveIssue(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(), issue.getKey(), true)
if (validationResult.isValid())
log.debug("Archiving issue ${issue.getKey()}: ${archivedIssueService.archiveIssue(validationResult).isValid()}")
else
log.error("Failed to archiving issue ${issue.getKey()}: Validation Failed")
false
Everything logs as though it is succeeding. archivedIssueService.archiveIssue(validationResult).isValid() returns true. However the issue remains unarchived. What am I doing wrong?
Thanks in advance,
Carl
Hi @Carl Adolfson ,
did you find a solution for this?
I first tried to use IssueManager.archiveIssue(). Result is the same as your code but not that save as we have no validation.
I can't find the built in post function in my instance (https://docs.adaptavist.com/sr4js/latest/features/workflows/post-functions/built-in-post-functions/archive-this-issue)
In console both custom scripts are working.
Then I tried to set up an listener, but it's the same result. Success is logged but issue isn't archived.
In the issue history I see that issue was archived but I think that Jira isn't done with reindexing and is saving the unarchived issue back to database after the attempt to archive it.
I will now configure the archiving issues job (https://docs.adaptavist.com/sr4js/latest/features/jobs/built-in-jobs/issue-archiving-job-data-center)
Regards
Hi @Erik Buchholz Did you by any chance have success with us. I tried using the inbuilt archive post function available within scriptrunner. The condition shows as success but the issues don't get archived. Even after trying to re-index the project, issue still aren't archived.
Hi @AisM ,
perhaps the post functions need to be in another order?
If it's not working with the built in function, I would suggest to ask the Adaptavist support.
Regards
PS: after working some time with the archiving job running in the night, I actually prefer this way, as the user can easier find the issue, if the decision for archiving was wrong.
@Erik Buchholz Thank you for the reply ! Actually I tried the above code instead of the scriptrunner build-in archive functionality.
Now, the code log shows as successful and the issue history shows as archived, but the actual issue doesn't appear archived. Really breaking my head over this.
