Are plugin licenses perpetual-use for a specific version?
eacwpku August 20, 2015
If I never upgrade, do I have to renew my plugin licenses every year?
Andre Borzzatto
August 20, 2015
According our "Add-on pricing FAQ" that you can find in any add-ons you browse in the marketplace:
  • How does add-on pricing work?
    Just like your Atlassian host application, there are two pricing models for add-ons. Pick the model that matches your Atlassian product, and the same rules apply:
    Server pricing
    • Products and add-ons are hosted on your servers.
    • Licenses last forever and include 12 months of maintenance (support and version updates).
    • You can renew maintenance after 12 months at 50% of the current purchase price.
    • You can upgrade the tier of your host product and add-on licenses at any time. Upgrade prices are calculated based on Atlassian's formula (view example).
So, I believe it's a yes.
Unless you want support for this plugins/apps you don't have to pay twice.
Hope this helps!
Daniel Wester
August 20, 2015
It depends on the plugin. For the ones sold through the atlassian marketplace - see Andre's answer. For the non-marketplace it depends on the vendor.
In either case though you'd probably not have support.
michael_ngangom
August 20, 2015
Hi Anthony,
No, but you will not have support and will not be able to upgrade.
Read the story
