Arranging version number in a particular order
Lena Movshovich December 15, 2013
Is there any way to arrange/sort order in the "version" drop-down menu?
It seems to me the last version added is always at the top of the list and there is no way to put the latest version number (not the one you created last at the top). Or let's say, I want trunk to always be the first on my list.
Thank you,
- Lena
Bob Swift
December 15, 2013
In administration, go to manage versions and re-order via drag and drop.
Thanks, but what do I select under the Administration?
Issue, Project, System, User Management...
Bob Swift
December 15, 2013
Sorry, on your version of JIRA, go to the specific project administration (tab), the versions should be in the list.
Thank you, Bob!
I do not think I can move anything around on that screen...
Bob Swift
December 16, 2013
Make sure you are on the adminstation tab (something like plugins/servlet/project-config/xxx/versions) and you have project administration permission.
Lena Movshovich December 16, 2013
Thank you very much, Bob! - it found it - works well.
Lena Movshovich January 20, 2014
I arranged all the versions in the oder I wanted using my Admin. rights, but when I am opening a new issue, they show up in the original (not the order I set up) order.
What am I doing wrong here?
Thank you!
