Artezio Burndown Chart not working
murthy manjunath
Hi Team,
I have installed one of your free plugin named "Artezio Burndown Chart" for JIRA.
However, I am facing issues with no data loaded on configuration.
Could you please assist on this request.
Steps:
I have installed the plugin
Added the gadget in one of the test dashboard
Entered the information required by the gadget
clicked on save
However no results were loaded on the gadget with gadget stays blank.
Here are the logs for you to debug.
2016-06-15 07:50:14,790 http-bio-8443-exec-1054 ERROR prakhars 470x1309728x2 1hfppp4 103.36.149.7,192.68.228.90 /plugins/servlet/streams [streams.internal.servlet.StreamsActivityServlet] Error getting activity
java.lang.NullPointerException
                at com.atlassian.streams.api.common.Either$2.apply(Either.java:176)
                at com.atlassian.streams.api.common.Either$2.apply(Either.java:173)
                at com.google.common.collect.Iterators$7.computeNext(Iterators.java:649)
                at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143)
                at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138)
                at com.google.common.collect.Iterators$8.hasNext(Iterators.java:807)
                at com.atlassian.streams.internal.StreamsCompletionService.registerFailures(StreamsCompletionService.java:152)
                at com.atlassian.streams.internal.StreamsCompletionService.execute(StreamsCompletionService.java:145)
                at com.atlassian.streams.internal.FeedBuilder.getFeed(FeedBuilder.java:69)
                at com.atlassian.streams.internal.servlet.StreamsActivityServlet.doGet(StreamsActivityServlet.java:71)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
                at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:42)
                at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:52)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)  <+2> (ApplicationFilterChain.java:303) (ApplicationFilterChain.java:208)
                at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)  <+14> (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XContentTypeOptionsNoSniffFilter.java:22) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241)
Dmitry Kintsel June 15, 2016
Hi, Murthy!
Please provide for Artezio team JIRA and Burndown plugin versions.
And please check: all issues for chart must have estimated time value.
Nicolas Bier June 20, 2016
I'm having a similar problem but the stack trace is a little different:
2016-06-20 15:47:54,573 http-nio-8080-exec-73 ERROR nbier 947x99935x1 nalqjr 10.36.64.232 /rest/artbd/1.0/chart/burndown-chart/generate [c.a.jiraboard.rest.ManagedResource] java.lang.NullPointerException
at com.artezio.jiraboard.util.impl.BurnUpDownManagerImpl.getEstimateByDate(BurnUpDownManagerImpl.java:202)
This seems to point to missing estimated time value like you mentionned. So I added
AND remainingEstimate is not EMPTY and originalEstimate is not empty
at the end of my query but still no luck.
We are using Artezio burndown 1.4 with JIRA Sotware 7.1.2.
PS: It would be awesome if the plugin could treat empty estimates as 0h.Would make our life much easier.
Register today
