Hi there,
I know you can do this for assignee. in the project settings. However is there a way to modify this to automatically assign the reviewer field based on component?
Dear Colin,
Natively, Jira doesn’t support what you need, however, there is a plug-in in the Atlassian Marketplace, called Role Extensions, that you might want to check out. It seems to offer something very close to what you describe, though I am not sure if you can use the Reviewer field specifically.
Hope that helps!
Alexander Beltz
