Assign issue based on customfield value
Connor Sims July 26, 2017
I am trying to assign a user based on a customfield value (If customfield value is West, East, Central, assign to user1, user2, user3)
Customfield is a drop down with 3 options, script is set as a post function as the first in the transition for the Create step and the Open step
Here is my code:
String userName;
switch(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("customfield_10602").toString()){
case "West": userName = "user1";break;
case "Central": userName = "user2";break;
case "East": userName = "user3";break;
issue.setAssignee(ComponentAccessor.getUserManager().getUserByName(userName))
Can someone help me figure out why it keeps going to 'Unassigned' despite saying the post function step succeeded every time?
Many thanks
BigBrother July 26, 2017
Have you tried using the email addresses as opposed to the user names? When Atlassian rolled out SSO earlier this year, it caused a lot of inconsistencies regarding where usernames are required instead of email addresses and vise-versa.
Learn more
