Assign issue to group in jira
Aditya kumar Madhira
Hi I want to asign issue to group instead of user by default.
Post function is helping me to assign different user but not group. Pleas help me
Community moderators have prevented the ability to post new answers.
Post a new question
Hi I tried this but not working
1. created a custom field group assignee
2. add notification scheme to change assignee but not working.
means not changing assignee
Managing Issues via Group Ownership
You can add a custom field to store which users and groups should be associated with a given issue. This is particularly useful for projects where a team owns all issues of a particular type.
To do this, set up the following:
  1. Add a group picker custom field to your issues.
  2. Configure an email notification in your project's notification scheme to be sent to the 'Group Custom Field Value'.
An issue can now be "assigned" to the group by selecting the appropriate group in the group picker. An email notification will be sent to the group.
This seems to be our solution. Can you test it and let me know.
Nic Brough -Adaptavist-
January 7, 2014
You can't do it. Jira expects assignees to be a single user account. There was a feature request for this, but Atlassian have closed it with "will not fix".
See https://confluence.atlassian.com/display/JIRA/How+do+I+assign+issues+to+multiple+usersfor workarounds
Paulie Rainbow January 7, 2014
That link is very helpful. But I can see why they expect a single assignee, it keeps issues from being ignored/overlooked. The Queue or "pool" option in the link you posted is a nice alternative to "unassigned." But it would also work to link it to a project or a release and leave it unassigned.
Peter Milakovich
January 9, 2014
I looked at the link, and we actually use the "Managing Issues via a User Account" option, and it works very well for us. Many groups use their group e-mail as the user e-mail address, and the groups that didn't want to receive all the notifies and just work out of filters used a bogus e-mail address. We've been doing this for about 8 months now without any issues.
Kristen Davis February 13, 2018
Hi! If you assign an issue to a group, shouldn't the issue appear in each respective user's open issues and on the assigned issues gadget?
Kristen
February 13, 2018
You can't assign an issue to a group.
Oh, I thought you could using the Group Assigned custom field?
What is the purpose of that field?
February 13, 2018
It's probably been added to your Jira by an admin to support the idea of "there is a group also responsible here as well as the assignee"
AJ Magcale
this has worked for me. i would not like to setup notifications for when the custom field group/team is change.
Yasmine Rifai January 21, 2014
One more question related , how can I restrict the group I added , as assigned to this issue to be only seeing this issue?
January 22, 2014
I'm not sure I understand the question, so I apologise if this seems like completely the wrong answer...
You need to start from the position that no-one can see any issues in Jira by default. Then you can set up rules that say "allow person to see project if..." and use things like "if they are in role X in the project" or "they are in group Y"
This still won't get you to "group can only see their assigned issues" though, it just stops them from seeing other stuff. The next step is to ensure all the groups have "browse" permission on all the projects they will be working in. This actually opens up the whole project to them, which is still not what you need.
So, the last step is to enable "issue security" and set security levels on the issues that match their group-assignee groupings. This will hide issues in the project unless the user matches the rule.
See https://confluence.atlassian.com/display/JIRA/Configuring+Issue-level+Security
Okay, just wanted to make sure of that. Thank you.
For me , I need to assign an issue for a group, I added a new custom field "Group picker , multiple groups" but it shows as a new field when I create an issue not in Assignee field, still can't add group to the field assignee
I can only select a user , not a group
January 21, 2014
It's not explicit here at a glance, so I'll say it clearly:
You can NOT use a group in the assignee field.
End of story, there's no workarounds, hacks, tweaks. The assignee is a *single* *user*. Nothing else.
The usual workaround is exactly what you've done - have a "group assignee" field. But this is totally separate from the assignee field.
Deleted user July 18, 2016
A workaround may be following for small teams . You can use the Mention Function.
In the issue you can mention your team members by @[name]
If you have a dashboard for your team members you can create a special issue filter/ filter box for issues where the member of the team are mention. With this solution it is possible that team issues or issues for the whole business members are available in the dashboard. It is a first step for the problem.
For team over 100 members is this solution very difficult.
BTW: Sorry for my bad English.
July 18, 2016
Mentions are very helpful in getting people involved.  But remember that the idea of multiple assignees does not work.
Mohammed Khadir
I think one thing you can do is use a Service account and a custom group email on the service account. So when the sa is chosen as assignee, it can still email all the users.
January 19, 2017
Yes, that's the "dummy user account" approach - the weakness is that it's easy to forget when no-one is the assignee.
January 9, 2014
Ok, so you're using a field as a way to keep a group informed about an issue.
That has nothing to do with the assignee field, so I'm not sure what the question is, or what is not working here?
yes. Notification will send notification itself to intimate users about issue.
From the url - https://confluence.atlassian.com/display/JIRA/How+do+I+assign+issues+to+multiple+users
1. I create groupasignee custom field in create issue screen.
2. next i create notification screen which is sending notification to users about issue.
Mean there is no way to change assignee right?
Only users must pick unassign issues to specific user after receiving an email ?
January 9, 2014
I don't understand what is not working. You say:
(Then you've pasted a chunk of the document I pointed you to, but I've no idea why)
Point 1 is fine, but point 2 and 3 make no sense. Notification schemes are about emailing users about changes, not changing assignee, and point 3 implies that you've not understood the document at all - it's some ways of representing that an issue belongs to a group as well as the individual assignee, NOT a way to change assignee.
Could you explain what you mean by "not working"?
Post a new question
Register now
