Hi Community,
Trying to build a workflow where a user creates an issue and fills out the amount field. If the amount field is >= $1000 it goes to UserA, if it's <$1000 it goes to UserB.
Can someone help and point in the right direction? I am using JIRA Cloud. Thanks.
Hi Michael,
It will be definitely a post function on your workflow. Let me check and get back to you
Unfortunately what you are trying to achieve will need a plugin. Attached are the post functions I have in my cloud version. Being a could customer doesn't give you a huge selection when it comes to plugins. Adaptavist ScriptRunner may help you since it is available for Cloud users.
