Assign to me gadget filter
Kathleen Yomo April 22, 2015
Hi, can I check whether it is possible for me to change the assign to me filter. For example, instead of fetching issues Resolution = Unresolved, can i fetch issue that are Status = Not Closed ? Many Thanks
7 votes
Udo Brand
April 22, 2015
No you can't change that. But what you can do is to create your own filter (My open Issues)
assignee = currentUser() and status != Closed
then remove the Assigned to me Gadget from your dashboard, add a filter list gadget to it, using the new filter (My Open Issues).
Zack April 14, 2021
Thank you @Udo Brand!
Not sure if the name changed since this post, but the gadget is now called:
Filter Results
Hi @Udo Brand,
Thank you so much for the recommendation !!
Register now
