×Hello!
I have a project that we store some user hierarchy
I try to set assignee in new issue in project TEST from this project, depending on customfield value.
But as a result i receive null and Assignee is unassigned
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.user.util.UserManager
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.user.ApplicationUsers
import com.atlassian.jira.ComponentManager
// any task where i want to change assignee
IssueManager issueManager = ComponentAccessor.getOSGiComponentInstanceOfType(IssueManager.class);
Issue issue = issueManager.getIssueObject("TEST-429");
log.warn(issue.key+ " id " +issue.id)
def finId = issue.getCustomFieldValue(customFieldManager.getCustomFieldObject("customfield_15208"))
Node fid = new XmlParser().parseText(finId)
long fcpid = Long.parseLong(fid.value.text());
// issue with
Issue fcpIssue = issueManager.getIssueObject(fcpid);
//fields from fcp
def user = fcpIssue.getCustomFieldValue(customFieldManager.getCustomFieldObject("customfield_15200"))?.username
issue.setAssignee(ComponentAccessor.getUserManager().getUserByName(user))
How to use setAssignee properly?
Can you output the result of the following line to the log and make sure you are getting the value you want?
Depending on the result of the above, we could confirm if you can set the assignee.
I would start with getting the value of the following:
Confirm you are getting the correct value first before we proceed any further. I would like to ask why you are not just parsing the issue-key directly from your customfield or something similar.
I will need more context to be able to help you further with the above.
Cheers.
logs:
WARN [runner.AbstractScriptRunner]: TEST-429 id 193718
WARN [runner.AbstractScriptRunner]: fid= content[attributes={}; value=[value[attributes={}; value=[206189]]]]
WARN [runner.AbstractScriptRunner]: fcpid= 206189
WARN [runner.AbstractScriptRunner]: user prokashik
tried with
issue.setAssignee(ComponentAccessor.getUserManager().getUserByKey(user))
same result
Try:
Ensure you persist the value with an issue update event. For example:
assetOwner = userManager.getUserByKey('myuser')
log.warn(assetOwner)
issue.setCustomFieldValue(assetOwnerField, assetOwner)
issueManager.updateIssue(user, issue, EventDispatchOption.ISSUE_UPDATED, false)
The last line ensures that JIRA persists your change in a post-function or event.
Can you give this a try and confirm if this is the same as what you are aiming for?
I find my problem
def user = fcpIssue.getCustomFieldValue(customFieldManager.getCustomFieldObject("customfield_15200"))?.key
log.warn("user " +user)
Thank You a lot for help, @Ismael Jimoh
It seems almost certain the the username that is returned from the custom_field is resulting in a value that doesn't return a user from the getUserByName() call. That is where I would focus. Make sure that you are getting a String value that is a username that can be found by the call.
Ready script for our free plugin Mygroovy
//def issue = ComponentAccessor.issueManager.getIssueObject('CUSTOM-17405')
def someField = getCustomFieldValue(issue, 43312) //field id
if (!someField){
issue.setAssignee(ass1)
} else{
if(someField.optionId == 38538){
issue.setAssignee(ass2)
def getCustomFieldValue(issue, Long fieldId) {
//ComponentAccessor.customFieldManager.getCustomFieldObject(fieldId)?.getValue(issue)
issue.getCustomFieldValue(ComponentAccessor.customFieldManager.getCustomFieldObject(fieldId))
ps. By the way, here we have scripted the templates of the scripts, the most frequently usecases, just copy and paste what u need. https://github.com/mailru/jira-scripts/tree/master/JIRA%20groovy%20templates
