Assignee Script working in console but its not working on postfunction
kalyan kumar
May 25, 2019
Hi
The below Script Its working in console to change assignee its updating in history perfectly
but the assignee to me place its not showing the assignee name   so please check it and let me know if any updates
import com.atlassian.jira.issue.CustomFieldManager
import static java.util.Calendar.*
import org.apache.log4j.Category
def loggedInUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issueManager = ComponentAccessor.getIssueManager()
def mySourceIssue = issueManager.getIssueObject("JP-1")
mySourceIssue.getSummary()
mySourceIssue.getProjectObject().getName()
mySourceIssue.getIssueType().getName()
ApplicationUser user =mySourceIssue.getAssignee()
log.error("user name "+ user.getName())
log.error("user name "+ user.getDisplayName())
// update user
String userName = "janakiram";
def userManager = ComponentAccessor.getUserManager()
ApplicationUser modifiedUser = userManager.getUserByName(userName);
MutableIssue mutableIssue = issueManager.getIssueByCurrentKey("JP-1")
mutableIssue.setAssignee(modifiedUser);
issueManager.updateIssue(loggedInUser,mutableIssue,EventDispatchOption.ISSUE_UPDATED,true)
Marcos Sanchez
May 27, 2019 edited
Hi!
As I can understand, you want to use the same script that you used in console, but in a workflow postfunction.
This code should work:
def issueManager = ComponentAccessor.issueManager
def userManager = ComponentAccessor.userManager
def loggedUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def user = userManager.getUserByName("") //there goes the username
issue.setAssignee(user)
issueManager.updateIssue(loggedUser, issue, EventDispatchOption.ISSUE_UPDATED, true)
It's the same as yours, but without setting the issue variable and without getting current Assignee.
You have to put it on a Script Post Function -> Custom Script Post Function.
Hope it helps,
Marcos
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
