Assignee cannot transition an issue
Angus Smith
HI team
I have a staff member with a very weird issue.
Rights: They have "config management" rights, and they are a team-member.
Issue: The system will not allow them to "transition" calls nor see the workflow.
Nikola Perisic
Hello @Angus Smith
  • Check the workflow to see if there are the transitions that don't allow the transitions of the issue from one status to another
  • Check for the Transition Issues permission as well
  • Check for the Move Issues permission as well
Matt Parks
April 17, 2024
The Move Issues permission is what allows them to change the project/issuetype of an issue. They will need to have the Transition Issues permission in the permission scheme associated with the project.
Also, under the top section, there is a 'View Read-Only Workflow' permission. They need to have that permission in order to view the workflow.
I don't know what you mean by "config management" rights, although I'm not sure it matters in this particular instance.
Angus Smith
I have done what you recommend, and waiting to hear from my colleague if it all works. Thank you Matt.
Angus Smith
Thanks Perisic.
Angus Smith
The user can see the workflow now, so thank you for that help, i did not know about that. He still cannot transition this call specifically. He came back to me saying he can transition other calls, but not on this specific project. I'm hoping that point will help narrow down the search.
Matt Parks
April 18, 2024
Can he transition any issue under that project, regardless of issue type? If not, he probably doesn't have the Transition Issues permission on the permission scheme for that project.
If he can transition other issues on the project, then the question is whether he can execute other transitions on this particular issue type or if it's specific transition. Either way, you'll want to look at the workflow to see if there are any Conditions on the workflow transition which he doesn't meet.
Angus Smith
Looking into this advice...
SERVER
VERSION
9.12.2
