Assignee column is no longer a dropdown
Ben S March 5, 2012
We upgrade to Jira 5 (v5.0#713-sha1:aec58e2) and the Assignee column is no longer a dropdown -- it's an open text field. Do I have to create a custom field or is this a bug?
4 votes
Jobin Kuruvilla [Adaptavist]
March 12, 2012
That rings a bell. Do you have 'Browse Users' global permission?
http://confluence.atlassian.com/display/JIRA/Managing+Global+Permissions
Deleted user March 12, 2012
Brilliant!
Thanks a lot Jobin, that worked for me!
Cameron Tudball
March 13, 2012
This was my issue as well.
aMarcus
March 26, 2012
Jobin is exactly correct,
In JIRA 5, the 'Browse Users' global permission is now required on users to show the list of available assignees in an issue. In previous versions of JIRA, there was less security on this drop down and any member of a project with the 'Assign Issues' project permission could see a full list of the users with the 'Assignable Users' project permission.
Ben S March 26, 2012
It wasn't until I had done a little research that I understand what Jobin was saying. Thank you!
I've the same problem, I guess it's a real issue.
It maybe has something to do with permission. When I'm logged as an administrator, the screen look like expected and the combobox appears.
March 5, 2012
It is a mixture of both. You can click on the drop down arrow in the extreme right of the text box and you can see it as a drop down. Alternatively, you can start typing the user's name and it will show you the suggestions.
Is that not working for you?
Ben S March 5, 2012
No, that's not what I'm seeing. I just have a text field. Rather strange.
March 5, 2012
Which browser? Can you add a screenshot?
Ben S March 6, 2012
FF 10, but I tried in IE 9 as well and I'm getting the same problem.
March 6, 2012
Works fine for me in FF10. And the above screen doesn't look like JIRA5. Something is wrong. I would raise an Atlassian support case!
