I am currently demoing the "Default Values for 'Create Issue' screen" add-on and have a question. I have a handful of issue types that I am associating with different view field configurations (some are normal issues and some are sub-tasks). The problem is that they are all part of the same project and with the add-on I seem to only be able to connect the project to one view scheme at a time.
Is it possible to have issues within the same project active and associated with different issue types at the same time? Basically, can I have the same project associated with more than one view scheme?
Thanks and please let me know if there is a way to do this.
-Michael
Thanks, Gebsun!
That totally worked!
Hi Michael,
This is doable!
You are right that it is possible to link only one scheme to a project. However inside that scheme you can link several field configurations (representing different defaults) to different issue types.
This way inside one scheme (linked to a specific project) you can link different default values with different issue types.
Let us know if that helps or you have more questions (I hope I understood your concern correctly).
Gebsun
