How do I associate multiple Jira Data Center projects to use the same Priority Scheme without deselecting the projects that already use that scheme? Clicking on a specific project in the list presented deselects any other project using that priority scheme. I tried using the Shift, Control, and Alt keys with no luck.
Regards - Steve Janvrin.
Hold Control or Command (Mac), just as you would do in an table, selecting rows.
If this doesn't work, try logging off and on again and clear you cache and history. or even try an incognito window
Hi Marc - this worked. My error was not pressing CTRL first before selecting/deselecting the appropriate project(s). Thanks for the quick answer.
