Associating custom field to a JIRA project
Mohan Krishnan
Hello ,
We are using JIRA 6.0 and clearcase for our development workflow . We have a super project - program A , which has multiple sub-projects or development lines B,C and D . All the 3 B,C and D subprojets have different clearcase stream hierarchy i.e the issues targeted to B,C and D will go to different clearcase stream . i want to have couple of custome fields associated to B,C and D sub projects -
Clearcase stream to which the issue should be delivered [ Can be a list of streams ]
A field CR_deliver_release to restrict delivery to the specified release tag - If we have planned 5 releases for a project - ED1, ED2 ....ED5 and want to specify that currently only ED1 and ED2 activities can be delivered .
I am looking for these custom field on a project level .
Kindly provide your thoughts .
Thanks ,
Mohan
Nic Brough -Adaptavist-
April 1, 2014
This is a standard "use a custom field and give it several contexts" task. Have a look at https://confluence.atlassian.com/display/JIRA/Configuring+a+Custom+Fieldand check out the "context" part which lets you configure fields differently by project/issue-type
