I am trying to build JIRA 7.5.1 source but the build was failed due to below error. Any suggestions please?
null
Found Banned Dependency: com.atlassian.browsers:atlassian-browsers-windows:jar:2.7.0-m1
Use 'mvn dependency:tree' to locate the source of the banned dependencies.
at org.apache.maven.plugins.enforcer.AbstractBanDependencies.execute(AbstractBanDependencies.java:112)
at com.atlassian.maven.enforcer.BanVersionDeps.execute(BanVersionDeps.java:81)
at org.apache.maven.plugins.enforcer.EnforceMojo.execute(EnforceMojo.java:193)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:132)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:120)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:355)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:216)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:160)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[WARNING] Rule 2: com.atlassian.maven.enforcer.BanVersionDeps failed with message:
null
[DEBUG] Skipping artifactory staging as maven build fails
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] Atlassian JIRA ..................................... SUCCESS [ 26.883 s]
[INFO] Atlassian JIRA - Code - Components ................. SUCCESS [ 0.477 s]
[INFO] jira-lucene-cutdown ................................ SUCCESS [ 1.842 s]
[INFO] Atlassian JIRA - Code - API ........................ SUCCESS [ 32.627 s]
[INFO] Atlassian JIRA - Code - DMZ API .................... SUCCESS [ 2.980 s]
[INFO] Atlassian JIRA - Code - Lucene DMZ ................. SUCCESS [ 3.761 s]
[INFO] Atlassian JIRA - Code - Core ....................... SUCCESS [02:04 min]
[INFO] Atlassian JIRA - Plugins ........................... SUCCESS [ 2.004 s]
[INFO] Atlassian JIRA - Language Packs .................... SUCCESS [ 3.451 s]
[INFO] Atlassian JIRA - Code - Parent for unit tests ...... SUCCESS [ 0.427 s]
[INFO] Atlassian JIRA - Code - Common Unit Tests .......... SUCCESS [ 15.569 s]
[INFO] Atlassian JIRA - Code - Test License Helper ........ SUCCESS [ 1.703 s]
[INFO] Atlassian JIRA - JIRA Configuration Tool ........... SUCCESS [ 9.860 s]
[INFO] Atlassian JIRA - Code - Unit Tests ................. SUCCESS [ 8.370 s]
[INFO] Atlassian JIRA - Code - Unit Database Tests ........ SUCCESS [ 9.729 s]
[INFO] Atlassian JIRA - Plugins - ActiveObjects SPI ....... SUCCESS [ 35.436 s]
[INFO] Atlassian JIRA - Plugins - OAuth Service Provider SPI SUCCESS [ 35.381 s]
[INFO] Atlassian JIRA - Plugins - OAuth Consumer SPI ...... SUCCESS [ 36.182 s]
[INFO] Atlassian JIRA - Plugins - REST .................... SUCCESS [ 1.937 s]
[INFO] Atlassian JIRA - Plugins - REST Plugin API ......... SUCCESS [ 4.229 s]
[INFO] Atlassian JIRA - Plugins - REST Plugin ............. SUCCESS [02:52 min]
[INFO] Atlassian JIRA - Plugins - Gadgets Plugin .......... SUCCESS [ 28.746 s]
[INFO] Atlassian JIRA - Plugins - SAL Plugin .............. SUCCESS [ 36.826 s]
[INFO] Atlassian JIRA - Plugins - WebHooks Plugin ......... SUCCESS [ 16.075 s]
[INFO] Atlassian JIRA - Testing - Func Tests Parent ....... SUCCESS [ 0.414 s]
[INFO] Atlassian JIRA - Testing - Func Tests .............. SUCCESS [01:01 min]
[INFO] Atlassian JIRA - Testing - UI Test Utils ........... SUCCESS [ 5.653 s]
[INFO] Atlassian JIRA - Testing - Page Objects Library .... FAILURE [ 1.330 s]
Hi!
Have you read this thread?
Gonchik Tsymzhitov
