This question is in reference to Atlassian Developer Documentation: Run your plugin in the container
atlas-run --product jira --version 6.1
JIRA 6.1 requires Java 1.7 while the newest Atlassian SDK can be run only under JDK 1.8
When I try to execute this command under JDK 1.8, initializing JIRA will fail due to exception:
java.lang.IllegalStateException: Cannot create ConcurrentHashMap - neither JDK 1.5 nor backport-concurrent available on the classpath
On the other hand, under JDK 1.7 the Atlassian SDK will rise an error.
How can I get around that problem?
Kind Regards,
Piotr
You can run an older version of JIRA with the latest Atlassian SDK version installed and Java 1.7 by specifying an older maven-plugin-version (AMPS):
atlas-run-standalone --product jira --version 6.1 --maven-plugin-version 6.1.2 --data-version 6.1
This works since the Maven AMPS plugin version 6.1.2 has been compiled with an older version of Java.
The options are available for atlas-run as well (see "atlas-run --help").
See https://marketplace.atlassian.com/plugins/atlassian-plugin-sdk-windows/versions for versions and compatibility.
The Atlassian sdk is using maven so if you set JAVA_HOME it should work. That said - JIRA 6.1 is eol:d...
