Hi I am new to this community. I am looking to call the JIRA REST API. The problem is when I try make a connection it gives me an authentication error: 401. I am using basic authentication via Python (Requests module). There is no additional security, so I am suspecting a firewall between my laptop and the JIRA server.
I have the server IP address, but I need the port number so that I can run a NC command.
Problem is no knows the port number ?
Is there a way I find this out programmatically or otherwise ?
Dani
Hi @Dani Rubin ,
Bydefault Jira tooks 8080 port without any kind of customization. Please check with this if it is workable for you or else you can get this information from Jira Admin by two ways :-
1) The base URL value listed in Jira's General Configuration page (https://confluence.atlassian.com/adminjiraserver/configuring-the-base-url-938847830.html)
2) The server.xml file tells Jira's application server which ports to listen on.
Prashant
Hi!
First of all, welcome @Dani Rubin
In that situation, you can double check does your Jira, works with SSO.
Do you have token for auth?
Did you try some package from pypi ?
https://pypi.org/project/atlassian-python-api/
Gonchik Tsymzhitov
Hi Gonchick
Generally we use SSL / AD authentication and I haven't required certificates for REST API.
I will look at that python package.
Thank you
Help us plant more trees
