Auto Populate a custom field
Sravan Kumar July 12, 2017
Hello Guys,
I am trying to Auto populate a Custom Field using the Script runner plug-in, is it possible? In my case i want the custom field "Fix Version"(used to enter the release date its a drop down field) to auto populate the current version(ABC) when a user moves the ticket from resolved to closed transition. Any help would be greatly appreciated.
Gaston Valente
July 12, 2017
Hi, you need to use a Script Post Function.
Here you can find some examples that use the fields you need to set
https://scriptrunner.adaptavist.com/5.0.2/jira/recipes/workflow/postfunctions/set-issue-attributes.html
Sravan Kumar July 17, 2017
Thank you. I was able to do that by going through the above link.
Register now
