Auto Transition of a ticket on a particular date
Amir Vegdani December 11, 2014
We create a ticket when we receive a job or task. However we don't start work on the ticket until a particular date (captured while creating a ticket under a custom field name "Project Start Date" and say we keep it in a status named "awaiting project start"
Can i auto transition this ticket from "awaiting project start" to "in progress" at that "Project Start Date".
Thanks for help in advance.
Cheers
Amir
Bob Swift
December 12, 2014
JIRA Command Line Interface (CLI) can help. Use runFromIssueList with JQL that finds all issues with the custom field value > now. Then use progressIssue for the action to run on each issue found. Put this in your favorate job scheduler or Bamboo to run once or day or similar.
Juan Felipe Cardona
December 12, 2014
Hello
I don't know of a way for triggering a transition on a given date. You could at least create a query and subcribe to it so that you get notified on that specific date and probably do a manual bulk transition on your issues.
Paula Silveira
December 12, 2014
Hi Amir,
You can change it on the workflow of the project.
Please check Configuring Workflow for further information.
Thanks and regards,
Paula Silveira
Amir Vegdani December 14, 2014
Hi Paula, Thanks for your reply on this. My Question here was is a inbuilt function for doing this or I need to write a script for this. Cheers Amir Vegdani
Can I use Post Function (Fast-track transition of Issue) to do this.
